| I was not able to locate on my harness where to re wire my sensor. As a temporary solution, can I make my own connection straight to sensor from the stock pressure gauge... Or does it need to run through the harness/ecu and a resistor or something. I just need it to make sure I get pressure upon my first startup. So if this won't work can I just use an aftermarket gauge? Thanks in advance for any help!
